Author Topic: Tps  (Read 1070 times)
Online Skinneroo
Tps
on: October 12, 2021, 07:14:29 PM
Does the tyre pressure monitor warn you if the level drops below a certain figure?
Re: Tps
Reply #1 on: October 12, 2021, 08:51:57 PM
Yes, and you can disable it in the TFT completely for track days.
Online Skinneroo
Re: Tps
Reply #2 on: October 13, 2021, 05:31:02 PM
How do you adjust the target pressure 🤔
Re: Tps
Reply #3 on: October 13, 2021, 05:47:48 PM
You can't, only disable.
Unless you're running really low pressure for a track day or shouldn't trigger the warning.  For normal riding conditions it shouldn't trigger.
Last Edit: October 13, 2021, 05:50:42 PM by rcb78
Offline MotoJoro
  • Town / City: Sofia
  • Country: bg
Re: Tps
Reply #4 on: October 14, 2021, 07:47:32 AM
One thing I love with the XR is the pressure is the same for riding alone and with passenger/luggage -  I don't know if BMW lies to make it easier for it's customers but all other bikes have different pressures.
Problem is that most gas stations don't have an accurate gauge and I have to carry one with me. With the TPS - problem solved! It is preset to 280 kpa (~2.8Atm) rear and 250 (~2,5Atm) front and you can't change it.
Last spring when i "woke" the bike from winter sleep the front was at 200 but there was no warning - I guess the warning goes on at at least 1 Atm (~101kpa) missing.
Offline Stonesie
  • Town / City: Doncaster
Re: Tps
Reply #5 on: October 14, 2021, 11:20:36 AM
Honestly, every bike that I have owned has had recommended pressures of 36f 42r (PSI) approximately 2.5/2.9 bar
It's just a standard that they settled on and I always soften them a little to 36/38 as I don't carry a passenger.
Offline Happyman
  • Town / City: Kentís Store
Re: Tps
Reply #6 on: October 14, 2021, 03:44:39 PM
*Originally Posted by Stonesie [+]
I do the same. At 180 pounds, no pillion and Michelin Road 5 GT tires (GT version has stiffer sidewalls) I lower my pressures to 2.4 bar front and 2.8 bar rear. Much nicer ride  :047:!
