Author Tail tidy with OEM luggage rack - 2021 F900XR  (Read 418 times)
  • Offline kiloohm   ca
    • XR Newbie  ‐    1
    • Topic Author
    Offline kiloohm
    • Topic Author
    • Bike: F900XR 2021
    • Town / City: Toronto, Canada
    • Country: ca
    on: May 15, 2023, 03:00:08 pm
    I have the OEM luggage rack on my F900XR 2021 (all 3 cases) and I'm wondering if there is any option for a tail tidy.
    The turn signal might get in the way so I assume I would need something like the Denali T3 turn signals.
    Open to any other options or installed pics would be even better. BTW this is for a North American license plate.
  • Offline goldfingerz   ca
    • XR Member  ‐    12
      #1
    Offline goldfingerz
    • Bike: BMW F900R (2020)
    • Country: ca
    Re: Tail tidy with OEM luggage rack - 2021 F900XR
    Reply #1 on: May 19, 2023, 01:10:58 am
    I can't help you with your tidy tail question, but I'm looking into installing a top case. To do this I plan to install part 77448396356 and 77449443938 on my f900r. However, I'm not sure what top case I'll be able to install. Will I be able to install, say a Givi top case, like fortnine.ca sells?
  • Offline CWMC29   ca
    • XR Member  ‐    47
      #2
    Offline CWMC29
    • Bike: Gold 2020 BMW F900XR
    • Town / City: Windsor, ON, Canada
    • Country: ca
    Reply #2 on: May 23, 2023, 12:48:13 pm
    *Originally Posted by kiloohm [+]
    Kiloohm, I have a fix for your question.  I put the Evotech tidy tail on my bike and realized that the factory tail lights don't fit with the factory hard bags fitted.  I went on to ebay and purchased a set of short stalk front turn signals and swapped them out.  I have included the link and some pics for you to see the difference.  Hope this helps.
    https://www.ebay.com/itm/324276061794
    Last Edit: May 23, 2023, 12:50:14 pm by CWMC29
  • Offline figbat   gb
    • XR Pro  ‐    95
      #3
    Offline figbat
    • Bike: F900XR TE
    • Town / City: South Oxfordshire
    Reply #3 on: May 23, 2023, 01:16:58 pm
    Looks great but what's the separation between them?  In the UK we need 180mm minimum between rear indicators; any less and you face being pulled over (unlikely) or failing the annual road-worthiness test (more likely).
  • Offline CWMC29   ca
    • XR Member  ‐    47
      #4
    Offline CWMC29
    • Country: ca
    Reply #4 on: May 23, 2023, 01:27:08 pm
    *Originally Posted by figbat [+]
    I forgot I made a post about the North American turn signal options (https://www.f900xr.com/index.php/topic,800.msg6168.html#msg6168).  Here in Canada, we do not have that regulation and we do not have to do an annual road-worthiness test.  My last post shows that I did measure the distance between the turn signals are 171.45mm.  Not sure if that would catch the eye of the local Constablary.
    Last Edit: May 23, 2023, 01:30:03 pm by CWMC29
